So I know what cyclic pitch is. However I'm not quite sure how to control cyclic pitch from a transmitter.
Looking at my humble LP5DSM, a 5 channel transmitter, I have two sticks. The left stick controls throttle and rudder (yaw), the right stick controls elevator and aileron.
Now as I see it, the throttle controls the speed of each of the two motors in unison, whereas the rudder varies the speed differential between the two motors, thus inducing torque, causing the nose to turn in the opposite direction of the torque. As such the left stick has no affect on cyclic pitch.
Therefore, the right stick must be the cyclic stick as it is only by changing the cyclic pitch that one can cause the heli to move fore or aft, port or starboard.
Am I correct or way off the mark? And if I am correct, where does the cyclic input come from? Is it induced by the flybar on the top blades?
And why do the more complex helis require more than 4 channels to fly?
Told ya it was a dumb question...
